laknox wrote:
wilber1 wrote:
spud1957 wrote:
For the F250, it doesn't matter what wheel package you have, the axle rating on the door post is 6200lbs. I have 18" tires @ 3500lbs each. My axle rating is 6200lbs.
If the OP has 18" tires and the camper package, he has an F350 structurally.
Why does the F250/350 topic always gets argued about!!!
S
If there is no difference between a 250 and a 350, why is there a 250 and a 350?
As was said, to fill a market niche. Also, many states' registration is weight-based, so having a lighter-rated truck means cheaper tags.
Lyle
Two things one if it just registration you do know that F350 standard GVWR is 10,000 lbs and anything above that is optional that has to be ordered as an option. Now, why is there a need for 250's?
Forest River 5er dry pins are way low. Below in my tag shows that...\
2015 Crusader 315RST 5th Wheel - Scale Weight 11,380 Pin Weight 2740 Lbs,
2015 Ford F350 SRW Diesel 440HP 865lbs Torque - Cargo Capacity 3744 - Tow Capacity 15,900 - GVWR
