Colo_Native's avatar
Colo_Native
Attention Weight Police
I went and weighed the TV and FW it is as follows:
Truck door sticker
Front axle GVAW 5940
Rear Axle GVAW 6100
GVWR 10000
Payload 3000
PER FORD max towing 15100
The combined is 23000
The actual CAT Weights
Truck
Steer axle 5020
Drive axle 3720
Gross 8740
With FW no water on board(60 Gallon Cap or 480 lbs)
steer axle 4820
drive axle 6080
Trailer 8200
Total 19100
The dry weight is 9926 and per Forest river hitch is 1953 carrying cap. 2389 per brochure
DOOR sticker GVWR 9931 Carrying Cap. 1963
it appears that the pin is to high if so what do I need to do to fix it?
  • Why do you think the pin is too high?
    Pin is generally around 20% of the fivers actual weight. Not the mythical brochure dry weight.
