- GoPackGoExplorerFIRST - I made sure to get an RDS tank that was lower then my bedrails. My 40 gallon tank/tool box combo is 1 inch lower. Also, I have heard they will build custom tanks - but they have MANY different tanks and tool box combos. I don't believe Northern Tools shows all of them - go to the RDS website and look around.
Then I went looking for covers. Never could find a hard cover that would work for me. So I started looking at soft tops. Came across the Truxedo Truxport and had it installed. $300 installed in 2013. I am very happy. No clearance problems and very weather tight. Can only be opened after opening the tailgate.
Now a Happy Camper !. Highly recommended. - ol_Bombero-JCExplorer
tomthyme wrote:
So here's the thing...
I love all the tonneau cover suggestions, but I am trying to find one that would fit over an auxiliary fuel tank.
Any recommendations on the fuel tank and tonneau cover combo for the 5er configuration?
Thanks guys!
The thing is - YOU need to do YOUR homework!..;)
There's PLENTY of options that will fit in your bed under almost any tonneau or bed cover!
It all depends on how much fuel you want to carry -vs- bed space sacrificed.
Do you want a true aux tank (plumbed) to your main tank -or- a reserve
which can be pumped into your main tank - or gravity fed?
Is the added weight an issue (for you)?
How much do you want to spend?..:@
Suggest you get a Northern Tool catalog and look at the (many) tank options and dimensions.
And of course - there are auxiliary tank companies doing professional installations to extend your range.
"Iron butt" is not really my "thing" - a stop for fuel after 350+ miles on my factory 35 gal tank is just fine and fits in with stretching my legs & a lavy call.
Consequently - for me - one of the 18 gal RDS tanks is "just there" as a reserve.......which I rarely "tap into", if ever.
BTW - RDS did a custom 50? gal tank featured in one of the mags, which was the *full* width of the truck bed and only about 8" wide.
Yeah - the filler on that one was taller than the top of the bed -
but you could have a "revised" model - - for a price...:W
~ - tomthymeExplorerThanks so much! Awesome pics and great ideas!
- racer4ExplorerWhat Pipeman said x 2.
The transfer Flow 50 gal should fit under a roll up cover or a flip/fold cover. Check the dimensions on the link that Pipeman gave. The 50 gal says 14-3/4" H+ 3" for the fill neck, so 17-3/4" H.
Picture of 50 gal. tank.
If you want a retractable cover, like a Pace Edwards Jackrabbit, look at the Transfer Flow 37 gal. tank designed to fit that application.
Tank picture
Tank Dimensions Graphic
A Jackrabbit will give you better visibility out the rear window (for hitching, etc). It locks in place every 12" to allow partially closed use. Transfer Flow uses a computer controlled pump to transfer fuel (instead of gravity flow and a check ball), and accordingly cost more. - jab764ExplorerI also have a Truxedo roll up cover and my Transfer Flow 50 gallon tank fits under it just fine.
- dapperdanExplorerI feel your pain, when I decided to cover my new truck I didn't want to have to change or give up using my RDS tank either.
My solution was to carefully cut a hole in the cover and reinforce it. I bought some material that looked like the same kind of material my Truxedo top is made of and glued a piece on the outside of it and the inside around that hole hoping that would help reduce the threat of a rip or whatever from the access hole. So far so good, I just installed it a few months ago but it looks like it's going to work out.
Dan
- B_O__PlentyExplorer III use a 62 Gal RDS wedge gravity feed tank with a Access Original model rollup tonneau. This is my second truck with that combo. The cover clears the top of the fuel cap by about 1/4 inch. The Original model has 1 1/2" high rails that the cover fits over. Extremely happy with both...
B.O. - Nutinelse2doExplorerWe have the RolBak G2 locking hard cover. We have a 45 Gal RDS fuel tank. The RolBak canister sits directly behind the cab, and the RDS tank fits under it and behind it. The aux tank is L shaped. We have room for a tool box behind that, with an AirSafe air hitch, and 2 Honda 2k generators. When the hard cover is closed, everything is out of sight.
Here are some pics.... About 1/2 way down on the first page
About Fifth Wheel Group
19,040 PostsLatest Activity: May 25, 2026
