schlep1967 wrote:
Unless your ratchet strap is in the middle of the awning, and I have no idea how you would do that, you can't bend the tube. Now if you decide to go crazy ratcheting it tight with a strap attached to each end of the tube, you could literally pull the support arms off the trailer or bend the arms.
Or do like I did.... I ratchet strap from the ends of the tube back to the trailer frame on the front end and the trailer wheel on the back of the awning. My mistake was I did this before putting out the living/dining room slide. When the slide got put out it bent the arm on the awning.
Well not an electric awning, but 21’ manual awning and three ratchet straps one at each end and one in the middle. The one in the middle is attached using two of the straps in the link. All straps just snug, awning out almost 24/7/365 as we are full time park host. If wind gets too bad I will take it in, but not too often.
Link
