Carlos & Ranae wrote:
. . . After moving the toyhauler back and forth a few times, the tires separated a little. While inspecting the other tires, I found threat separation on driver side rear tire, which I replaced with spare tire.
Rather than having it tow to repair shop, I was thinking of removing the middle tires and bring it to the shop myself. Any advise is welcome. Traveling distance is 12 miles. We are staying put until March. By then, it will be sporting Sailun or GY.
If it was my rig, there's no way I would tow it on a public highway until I crawled underneath to verify the exact cause of the mis-alignment beforehand.
A broken weld? Broken/bent shackle/hanger? Missing suspension bolt? Broken/loose u-bolts? Broken/bent spring?
If the problem is completely isolated to the middle axle, it *may* be safe to tow it with the middle tires/wheels removed. Hard to say for sure without seeing your suspension firsthand.
