Jlschuma's avatar
Jlschuma
Axels seem off?
I have a double axel and when you look at the tires one looks angled different than the other at times. Is this because they are on leaf springs or is it a problem. The springs and axels all look good when I check underneath.
  • Jlschuma wrote:
    I wonder why the search feature on the forum never gives me many results.
    because the default is 'exact phrase'. the more words you use the worse it gets. That, and possibly your spelling, although 'axel' is common on here.
  • Thanks. That is probably it is was pulling back bad forth to get inot a spot.
  • "At times" indicates it is most likely due to backing the trailer at an angle. They will appears out of line, but no problem as they will straighten when you pull forward.
