Charlie_D_
Aug 08, 2018Explorer
Lynnmor wrote:Charlie D. wrote:DougE wrote:
Check on the price of a replacement axle. It may be a reasonable alternative.
Even with new axle it will have to be aligned.
Do you think they are aligned from the factory?
I think you will find that they are bolted in and sent down the line.
And how to they set the distance between the tires? Is bolting the axle to the spring pack "close enough." Not just a matter of caster and camber. There is often a locating pin on the axle and a hole in the spring pack to do a rough set but I have seen several without those locating pins. I had one axle that shifted and one side was 1 1/2" closer to the tire than the other.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
