Both tires on the door side of my trailer are showing are showing quite a bit of wear on the outside two inches. The tires on the other side are wearing perfectly. I have one small slide on the door ...
If the tires are showing wear on the OUTSIDE edges, then that is NOT due to overweight. If over weight, they would show more weight on the inside edges.
Likely, you need a wheel alignment. And likely your spindles are bent under. And likely for pinching a curb on a right hand turn.
