rtate
May 29, 2014Explorer
Axle Alignment
Both tires on the door side of my trailer are showing are showing quite a bit of wear on the outside two inches. The tires on the other side are wearing perfectly. I have one small slide on the door ...
rtate wrote:You could do it yourself if you have a rack with a way to chain it down and a 20-100 ton hydraulic ram to pull it with plus a set of lasers to check your progress. In other words probably not. Leave it to the pros who do this everyday..If they are trusted to do someones semi or million dollar bus or motorhome, I would trust them to do my trailer. Had mine done last year and it came out great. They will give you your before and after specs.B.O. Plenty wrote:
Bring it to a big truck/trailer alignment shop, not an RV dealer. An alignment shop will have the equipment and knowledge to get it right for under $200.00. An RV dealer will just replace the axle and hope it's straight for WAY more money.
B.O.
