rtate
May 29, 2014Explorer
Axle Alignment
Both tires on the door side of my trailer are showing are showing quite a bit of wear on the outside two inches. The tires on the other side are wearing perfectly. I have one small slide on the door ...
taken wrote:Correct Track will only adjust one facet of your wheel alignment. It is not a cure all. It will allow adjustment for tracking (How square the axles are with the frame) but nothing else. You still need to deal with toe (wheels pointing toward or away from each other)and camber adjustments (wheels tilting in at the top or bottom). Only a good heavy duty alignment shop can do this. They will also adjust the tracking without have to spend $$$ on a Correct Track system.
Have you considered trying the Correct Track 2 system to align your axles?
