Izzy211ExplorerOct 19, 2016Axle issueRecently purchased a new Starcraft 5er. Upon inspection all break pads are shot. Pads peeled off of shoes. Upon farther investigation found axles rated at 4400 pounds each. GVWR of 5 er is 10,500 poun...Show More
downtheroadExplorerOct 19, 2016Welcome to the Forum:Others are correct, the axles are within specs.Just thinking...As for the brake shoe issue - check you break controller for proper adjustment and make sure that your break-away pin was not pulled.
Related ContentTowing lights issueaxle replacement issueLippert axle issue12 Volt Power IssueElectrical outlet issues
