Recently purchased a new Starcraft 5er. Upon inspection all break pads are shot. Pads peeled off of shoes. Upon farther investigation found axles rated at 4400 pounds each. GVWR of 5 er is 10,500 poun...
The brake issue will be a warranty item, but should have never happened. If they got hot enough to peel off, I'd want the drums checked/turned/replaced, if out of round or grooved.
The axle thing is marginal, but typical. If they would have used the 5,200 axles, you would have larger drums/better brakes, and added CCC.
