Jerry_BExplorerMay 25, 2013Axle nut sizeAnyone know what size the axle nut is on a Dexter Nev R Lube 7000 lb, 8 bolt wheel? Thanks
BusdriverExplorer IIMay 26, 2013And the best place to buy is tractor supply. They are 3/4 drive so you will also need a 3/4 to 1/2 reducer
Related ContentBattery wing nut size3500 lb. axle castle nutAxle Spindle Nut WrongAxle nut retainersAxle size?
