Golden_boys
Aug 13, 2014Explorer
B & W Hitch
Need some info if anyone has installed a bed saver onto the B & W Companion Hitch. We have the hitch that was made for the Ford truck. Thank you Semper FI
WeBeFulltimers wrote:
I believe anyone who would have a bed saver with their B & W hitch would also wear a belt AND suspenders with their pants!
Cummins12V98 wrote:
For those that don't have a B&W do your pull test! I used to with the RBW I had. When you actually use a B&W and look at the simplicity of the latching system and the thick wrap around jaws you will understand the only test you need to do is with your EYES. Yes that is a TEST.
Back under get out and close the latching arm and LOCK it. Now LOOK to see if the hitch and kingpin plates are touching. Now LOOK to see if the 1" thick bright silver jaws are wrapped around the kingpin. That is the ONLY test needed with a B&W.
Ok flame on B&W critics!
fj12ryder wrote:
The point is that a bed saver is a waste of money with a B&W hitch. Obviously a person can screw up anything if they work at it hard enough, but the odds of it happening with a B&W hitch are huge. You have to work at it to drop your 5th wheel with a B&W hitch.
If you're paying attention it is impossible to "hi pin" a B&W hitch, pure and simple. Notice the wording: "If you're paying attention". You simply cannot "hi pin" it without it being impossible to miss "If you're paying attention".
I suppose I could drive off without being aware that I've left my 5th wheel behind, but I guess it could happen...just like "hi pinning" a B&W hitch and not being aware of it. :)
fj12ryder wrote:
The fifth wheel latch kit is just one more thing to remember. If you are going to have a bed saver it needs to be automatic.
ricatic wrote:
I have been down this road. When we bought our Big Horn, it was our first fifth wheel... The truck we bought to pull it already had a B&W Turnover Ball Gooseneck hitch installed. After only a bit of research, we bought the Companion to go with it. I then proceeded to talk myself into the Bedsaver...after only a very short time. realized that the design of the Companion makes high hitching the fiver virtually impossible...if the jaws close and you can put the safety pin in the hitch, it is hitched...period...cutting to the chase, I would not buy a Bedsaver today to put on a Companion...
Regards
