fj12ryder
May 18, 2017Explorer III
The proper tire choice depends on your GVWR, or your actual scaled weight, axle rating, wheel rating, number of axles, and your particular decision.
You can put "E" rated LT tires on if they will carry the weight with a safety margin.
Or you can go with "G" rated ST tires if your wheels are rated for the higher pressure.
Or you can roll the dice and go with another "E"rated ST tire. I don't recommend this option.
About Fifth Wheel Group
