mabynack's avatar
mabynack
Explorer II
Oct 30, 2014
Bad Trip
My last trip in my fifth-wheel was pretty bad and it's been hard to get motivated to go again.
The truck overheated and I took it to three different shops along my route. They charged over 300 dollars and never found the cause - it turned out to be a blown head gasket.
My front jacks wouldn't extend and I had to cross-wire the leads to the motor to unhook the RV.
My 12 volt system quit working so I lost my fridge, electric jacks, and the ability to put my slides in. The campground that I was staying at insisted that I had to leave NOW, despite the fact that I couldn't get the slides in or the jacks to retract.
I blew two tires that were less than a year old and it did about 1500 in damage to the RV.
I slid off a slick clay road and got stuck at 11 p.m. in a remote part of North Carolina.
After all of that, I'm now trying to get the truck and RV fixed so I can take it out and see what else has broken while it sat unused.
  • I see you're a Good Sam member. Next time you run into bunches of trouble, why not call a Stand By Sam? There's 115 volunteers in North Carolina, including me. Someone local might give you a name & number to a good garage or dealer or might be able to lend a hand. Could save you some troubles.
    Good luck on your next trip.
  • Other than that Mrs. Lincoln how was the play? Wow, things like that happen to RV ers, but not all at once! The way I figure it you should be trouble free for at least 10 years!
    So other than an otherwise normal eventful day, how do you like RVing?:E
  • wow is right, if you didn't have bad luck, you wouldn't have any luck at all.
  • I don't know if this will help anyone, but the way I finally got my slide to go in and jacks to work is that I bought one of those portable jump starters and connected it to my rig battery. In the future I plan on carrying a portable battery charger - it would do the same thing and also charge the battery if the converter goes out.
