sheltieRV's avatar
sheltieRV
Batteries not pulling slides in after day of dry camping
Hoping someone can give me some ideas. We dry camped for a day, when I went to pull the slides in the next morning, the first one came (though a bit slow) but the next 2 the motors would not turn at all. I started my truck and plugged in the trailer and then I was able to get them in normally.
I have 2 6volt batteries (only 4 months old). The battery meter said I had 3/4 power left. I measured the voltage today on each bat and it is 6.7 volts. I also checked all the battery and breaker connections and everything is tight. I have dry camped for days and have run the batteries down much lower with no problems, so I am a bit stumped as to what is causing this.
Any ideas?
  • bpounds wrote:
    I suppose you were using the original 4 light meter for checking the capacity. You can't really tell much truth with that.
    Sounds like all the slide equipment was working okay, since it worked when you connected truck power.
    Question is, why was your power level so low after only one day of dry camping. Did you consume a lot of power? Is your converter doing a good job of charging? When had you last connected to power for the charger to work?
    We dry camp a lot and have never run into this before. Since we were out in the middle of nowhere, I was more concerned about getting the slides in than diagnosing, so I did not put a volt meter on it. But now the batts are fully charged, so I know the converter is charging just fine.
    And yes, I know the dummy lights are just that, but they have worked well for me to gauge things in the past, so I know they are not the problem.
    If I had a bad cell in one of the batteries, would that cause something like this?
  • I suppose you were using the original 4 light meter for checking the capacity. You can't really tell much truth with that.
    An inexpensive voltage meter tacked on the wall can really help diagnose these things. The factory battery gauge, not so good.
    We dry camp a lot, and as a matter of practice I do my landing gear adjusting, and sometimes even my slide operation, while my truck is still connected to the trailer cord. Those motors draw a lot, so if I want to conserve power for dry camping I might as well let my truck share the load as much as possible. It is better for the motors too if they get plenty of juice. Low juice means they get hotter.
    Is that virtually the same reading you would have gotten at 3/4?
