A.Miel wrote:
Battery disconnect is on.
Battery has been dead for 3 days.
Yep I will charge the battery separately. But still want to be able to use some low-level power from the house to keep the battery charged and use some lights. I had understood that power from the extension cord should BOTH charge the battery AND supply immediate power. Aside from the battery issue (at this point) shouldn't there be some power coming into the rig through my setup?
Or am I still missing something?
No, you aren't missing anything. You should have lights and other things working while the battery is charging when plugged in like that.
Where exactly are you located? If your not far I could take a look.
Have DVM will travel! :B
