kansanforlife's avatar
Apr 15, 2016
Battery location
Acquired a 1993 hitch hiker and can't locate the battery or 12 volt fuses. Did have 12 volts on but dont now. Anybody know were there at? It's a 27 footer.
  • Called nuwa they didn't for sure we're battery was located but did tell me fuses was inside of inverter so found them and did find battery in front alcove but you have to remove shelving to get to it. Have now figured out inverter stopped working. Thanks for the replys.
  • Start opening outside compartments. The PO may have removed the battery, so start looking for loose wires.
  • The batteries are probably in a battery compartment that has a door about the size of a battery. Probably up front somewhere.
