Lwiddis wrote:
“I was taught how the constant solar charge is not enough amps.“
What? In good light my panels putout 16+ amps. It’s the batteries that determine how much they will accept...bulk, absorption, float and equalization. Did you mean volts? Note batteries are full, 1.9 amps is mostly parasitic, 17+ volts.
Oh weird not sure how i missed this. Why is it showing 17v, is that panel voltage? I only know the very basics of solar so far. Even if my setup was able to do 16 amps i still would not consider that adequate for my main charger. But it would be great while out camping.
I still think there are times you are better off unhooking the batteries. Let them self discharge. If its a day you are exercising the generator first toss a bunch of lights on. Drain the batteries to a certain level. Then blast them with the charger that came with the trailer when the genny is running. Only because its most likely a much higher amp charge than your average solar setup.
If you are on shore power then you would have more freedom to decide when to use the trailer charger.
To me its a mistake to have a trailer on shore power, battery switch disconnected, but solar hooked up. I had batteries die quickly doing that. I used to think they got fried, overcharged. Everyday sitting there at float voltage in the hot sun. Then i was taught the reason my 2 year old batteries died was from being undercharged. My solar setup could never hit them with a nice strong charge. Which is needed to keep the plates nice and clean. Is how i understand it. Same reason to do a 16v charge is to bubble those suckers.
Still curious what people would consider to be a minimum charge rate in terms of a % of C20.
