rainmanrv's avatar
rainmanrv
battery vent box
hello fifth wheelers I have a 2011 heartland sundance and would like to change from 1 12volt battery and go to 2-6volt battery.I did this before with my travel trailer with no problem.my front compartment were they will go is seal right now. I need vented and sealed battery box camping world says there is no such box for deep cell 6volts battery. Can i use the standard deep cell battery box and vented it with some 2in hose. I am concerned about the gas it could give off because these box are not sealed. any ideas would be helpful.
  • RoyB's avatar
    RoyB
    Explorer III
    Check out the NOCO brand of battery boxes on-line- They use to have a couple of models designed especially for the GC2 GP24 DUAL 6VDC Golf Cart Batteries. You can modify almost any of the lids for these boxes for venting to the outside using hoses and a vent head. Lowes carries such items... If you find a suitable NOCO brand dual battery box you like you can probably purchase this thru AMAZON...
    Batteries do vent fumes when being charged that needs to vented to the outside of the trailers..
    My fifth wheel uses a depressed area just inside the front door of the basement area. It has two battery vents on both side. It also has a rail where the batteries are that will drain to the ground if the battery boxes fill up with water or battery fluids... My 5th wheel bedroom is just above this area so it was very important to me to have vented battery compartment as well as the Propane compartments mounted on both sides of the trailer in an enclosed area in the same area.
    Never really liked the idea the batteries and propane were almost directly under the sleeping beds.
    My other pull trailer has the propane tanks and the batteries on the outside tongue area.
    Roy Ken
