dlowr31733 wrote:
ok people  one more time, lower plate and upper plate don't come tog  ether.  entire weight of rv is being carried by the pin. the pin is the pin  it is not a weight carrying device.  the weight of rv is carried by the plates, the object of the teflon disk is for anti-friction in lieu of grease  again, a pin is a pin not a load-carrying device.
So to be clear, you are using a teflon plate? When hitched up there is clearence between teflon disc and plate of pin box?  You are not expecting the teflon disc to compress and both plates sit on top of eachother? A pic would help.
