MFL
Aug 09, 2015Nomad II
With 3 being 95, seems odd that 4th would be more than 5 degrees different. The sun side can be warmer sometimes, but then 2 would have been 112.
It is possible one brake is dragging a little causing a higher reading on one hub.
A 112 temp is not high, but being different, I'd check it often for a while. Sometimes we over think things, causing unnecessary worry, when you've had no problem, the last 20,000 miles.
Jerry
Jerry
About Fifth Wheel Group
