WrightOn's avatar
WrightOn
Explorer II
Jul 09, 2018
Bedroom slide stutters - Cedar Creek
During a recent trip, the bedroom slide closed without an issue. After arriving at our next location, the slide had a very difficult time going out. It started out normally, but after about 8", it began to act as if it was binding on something. It would release and "jump" out about 6", then catch again. Through this process, the slide did go out completely, and the other two slides went out without an issue.
Things I've checked: hydraulic fluid is full; nothing is in the way of the slide mechanism (located under the bed); slide topper seems to be rolling fine; the left and right sides go out equally.
Any suggestions?
  • Lift bed, access the mechnism and lubricate everything with dry lube.
