- JRscoobyExplorer II
cummins2014 wrote:
JRscooby wrote:
When welding frames I always clamp stands well past the area I'm working to pull a strings tight, then notch a sticks for gauge. Short weld, skip weld another place, other rail whatever, then come back, repeat...
Okay, read up a little on skip welding as they call it, still stitch welding, but its actually back welding for heat purposes , but then coming back , and actually seam welding or a complete weld, only for the purpose of heat distortion.
We did a lot of pre bow. Pre bow on base plates that required a seam weld was much easier to just put in an established pre bow , let the heat pull it back straight, instead of having to mess with a bunch of stopping ,and starting welds. Of course in these frame applications ,thats not possible .
I'm sure if doing enough to know how much the welding would distort thing would be good. But I was working in a gravel parking lot, with portable tools. Need to cut the rail at angle? Clamp guide block to rail, mount a cut-off wheel on the skill saw. Use grinder to bevel the parts that hard to bevel once parts are stuck together. Use the easy to grind corner to check alignment, weld the parts that where ground, let cool, grind some more, repeat... - cummins2014Explorer
We did a lot of pre bow. Pre bow on base plates that required a seam weld was much easier to just put in an established pre bow , let the heat pull it back straight, instead of having to mess with a bunch of stopping ,and starting welds. Of course in these frame applications ,thats not possible . - JRscoobyExplorer IIWhen welding frames I always clamp stands well past the area I'm working to pull a strings tight, then notch a sticks for gauge. Short weld, skip weld another place, other rail whatever, then come back, repeat...
Me Again wrote:
Lynnmor wrote:
Lippert actually has a part number for patching their pathetic frames. While it is much shorter than your proposed fix, it shows the need for it. Patch
Our 2005 Cardinal 29WBLX with cracks is the web of the I-beans. Lippert called for welding all the way around the fish plates. My welding shop disagreed and skip welded around the edge on the fish plates and did a plug weld over the repaired crack per my suggestion. Chris
Although stitch welding is no where near as strong as seam welding, the extra heat is the problem , it may warp whats being welded, or just the fact stitch welding is sufficient . But if its possible, and will nor warp ,or braced so it won't I will weld it solid . Its never bad to weld it solid if possible .
Plus its always good to dig it out a bit before welding for better penetration. - Bert_AckermanExplorer
cummins2014 wrote:
Me Again wrote:
ivbinconned wrote:
Well you all have convinced me to do this.
I will use 3/16 plate 12 feet long min. I’ll jack the back end up a hair if need be to true it up.
Thanks for your comments.
Be sure to skip weld it! Chris
You do mean stitch weld it :)
I'd be careful doing that skip welding, might not want to broadcast you've done it.. I am pretty sure Lippert holds the rights to that skip welding. - cummins2014Explorer
You do mean stitch weld it :) - Me_AgainExplorer III
- ivbinconnedExplorer IItrailers are my business. I repair them and build them. I think that any “flexibility” should be addressed in the suspension. If I were to order a 12,000 lb. Trailer new I would insist in 7k - 0 degree torflex axels. This would then require a “cart” frame in order to obtain enough height.
A smoother ride I don’t think one could find.
Regarding the attachment of “fish” plate I would be spot welding and using a good many “Huck” rivets. - Me_AgainExplorer III
Be sure to skip weld it! Chris - cummins2014Explorer
Are you sure what you call rear frame sag is not frame camber by design? Perhaps a call to Cedar Creek or Lippert is in order? If you start jacking out camber designed in and holding it by welding in flitch plates or stiffeners, you may create issues you currently do not have.
I agree there does become a point where its to rigid, there has to be some flex. Same with the pin box.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
