jodeb720's avatar
jodeb720
Bent Kingpin?
Greetings all.
I got a new truck - and a new hitch - thanks to you all for your opinions.
Hooked up the new hitch and the trailer and the world looked good - after some height adjustment.
Things looked good. Until tonight.
As I pulled into Santa Fe on my way back to Denver, I was looking in the rear view mirror and thought the spacing between the bed and the bottom of the 5er was small. So I Pulled into the Motel and stepped back. The entire kingpin looks like it's bent upwards - and had actually bent the front fiberglass nose of the 5er.
I've never seen (let alone heard of) something like this.
Tomorrow I can raise the hitch up - but I don't think that's going to stop the collapse of the kingpin into the nose and eventually it'll hit the bed of the truck.
I have no idea what I'm looking at - if I can risk the 400 miles to Denver.
Since I've never disassembled the plastic around the tongue to figure out what's behind it, I have no idea what i'm getting into (and won't until tomorrow.
It's a Lippert chassis - cougar 244rls 2010
Thanks in advance!
josh
  • If it were me, I wouldn't go any further until I knew the extent of the problem. It sounds very much like the frame is flexing and bending under the covering in the nose. Either broken welds, or broken frame. You should be able to remove the lower covering and see the issue. But much moving anywhere is going to make it worse.
