X10 on the Rhino!
Best thing I ever bought for my MH as sad as that sounds. :B
Buy the
Rhino Sewer Hose "Kit" contains all the connections you will need. As some are required at CG's. The hose is rigid and expands and contracts to what ever length you need and is 'real' easy to handle, clean and store.
And add this too, I don't leave home without it.
Sidewinder Support: This is the sewer support that allows you to be able to hook up from any height or angle and/or around trees and expands and contracts for any distance, so it flows easily into sewer hook up.
___
10 years and counting on original purchase and not one single leak.
Both of these can be found at Walmart!
