speediq99's avatar
speediq99
Explorer II
Nov 15, 2021
Best sliding hitch recommendation
Hello,
What is the best sliding 5th wheel hitch out there?
2022 F350 crew cab diesel 6.5ft bed
Towing 14k 40ft 5th wheel
Side question, are these things easy to install if you have the holes in the truck?
Thank you
MC
  • I’ve used a Superglide for the last 7yrs and ~60k miles. Love it. Numerous times it’s automatically prevented me from punching out my rear window even with a “new rounded corner” 5er. Will be moving it to the 2022 F350 when I get it (ordered).
  • Agree with 4x4ord...Many of us Ford owners are using a non-sliding hitch in our 6.9 ft beds.
    Get the B&W 3300 for Ford oem factory puck system. It is a great hitch, light wt, can be adjusted ahead/back, up/down, quiet/no rattle, user friendly (what's not to like).
    It easily separates to 2 pieces, and fits the pucks nicely. Your wife will have it installed in just a few minutes!
    Jerry
  • 2112's avatar
    2112
    Explorer II
    I was under the impression I needed a sliding hitch when I upgraded to a FW so I bought the Superglide. What a pain in the rear. About every third or fourth time I had to remove the head from the mount to disconnect it from the pin.
    I changed to a Reese manual slide. I realized with this hitch in the tow position I can maneuver over 90° without contacting the cab. I never needed a sliding hitch.
    I have a 14K Superglide rusting away in the barn I need to get rid of.
  • 4x4ord's avatar
    4x4ord
    Explorer III
    My personal opinion is that a sliding hitch is unnecessary especially with the new fivers. The nose of the newer fifth wheels is designed to allow adequate clearance while towing with a 6.5 foot bed.... I like my B&W nonsliding Companion. If I had a manual slider I would never take the time to unpin and slide it. If you feel you need a sliding hitch I would recommend an automatic slider such as the Superglide by Pullrite.
    click
