Cummins12V98
Nov 06, 2021Explorer III
TXiceman wrote:
Dry Weight14,344 lbs.GVWR16,800 lbs.Hitch Weight2,686 lbs.
The loaded pin weight will be 3360# or more.
I would not order anything less than a diesel dually for that much trailer. People that are using SRW trucks on these larger trailers are just kidding themselves.
Ken
Those numbers won’t hold up in the real world. Minimum 20% pin on that RV will be 4,200# and likely much higher. That RV simply does not stop gaining weight at 16,800#.
My RV has a 21k GVWR but somehow the loaded weight is 24k.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 10, 2026
