Omer&Donna wrote:
We have snaked from toilet, from drain valve and from vent on roof and black tank will not drain. Valve is open since 15 foot snake went in. Many chemicals added to loosen clog but nothing is working. Any suggestions?
You also stated level is inside the toilet bowl.
Then I bet the valve is NOT opening. 15' foot of snake may have gone up the dump line but all it did is turn around/coil up when it got to the valve......otherwise tank would be draining if snake went into tank.
Can you SEE the valve ....or is it hidden inside an enclosed underbelly?
Cable operated drain valve?
Until you can physically verify that the drain valve is actually opening I would not waste time on 'ice' (too much liquid in tank and it doesn't really work to unclog a tank) or paying plumber $$ to run a camera.
Drain valve........NOT OPEN
