- JEBarExplorer
Dave H M wrote:
stetwood wrote:
The only time I do not use blocks is on concrete pads.
Same here or is it spose to be X2 :)
X3 .... we use 15" X 15" Bigfoot Outrigger Pads under our Bigfoot auto leveling system jacks .... over the years we have tried the plastic lego blocks and various configurations of wooden blocks .... none work as well as the Bigfoot Outrigger Pads .... note, Bigfoot leveling systems and Bigfoot pads are made by two different, completely unrelated companies
Jim - wittmebaExplorerA better picture and each block has a handle.
The 2X4 spanned across the width of the trailer so I could move them both from one side.
- deleted-2Explorer II
wittmeba wrote:
A little off topic - If you look close between the wheels, you can see these are a piece of 6"X6" about 18" long cut in a trapezoid shape. There is one on each side. With a 2X4 nailed to the top I can insert/remove them both from one side which makes it convenient for blocking the wheels.
Hmmm...
I like this idea wittmeba.
Thank you for the pic.
I have a chunk of 4x6 I was going to use for chocks.
The tires are too close together on our fiver to use the pricey X-Chocks anyhoo.
The 2 by nailed on for a handle is pretty handy. - Dave_H_MExplorer II
Same here or is it spose to be X2 :) - wittmebaExplorerWe used these in our sloped driveway and turn them over when on level ground. They are 2X8X16" long with a cross-piece nailed to 1 end. The main reason is on some soil they do increase the surface and reduce sinking.
- deleted-2Explorer III always put wood or concrete blocks under the landing feet.
Did it on the rear to save the labor having to crank the jack down so far.
Now the rears are powered by 12 volts.
Don't know why I place wood blocks under the front electric jacks.
I think someone told me the front feet are less likely to scoot if placed on wood.
Looks like I may have discovered a waste of my time fooling with wood blocks on a level pad. :) - VulcaneerExplorerI never use plastic. Always use wood. And only 2" thick on front. I do have a couple of 12" thick wood blocks. I never use those on the front. Only for use in the rear, if needed.
If I need more than 2" thick in the front, I'll get another site. Propping the front up too high is not something I ever do. - Water-BugExplorer IIOne thing that hasn't been mentioned is that too much block under the landing gear of a 5er can prevent you from lowering the front end enough to level the trailer. This is especially true if you tow in a slightly nose up attitude. I use to put maximum blocks under the landing gear to limit travel and wear, until once when I couldn't bring the front end down enough to level the trailer.
- C_B_Explorer III put down 6- 2"H x 8"W X12"L blocks under my level-up system.
C.B. - buc1980ExplorerI use wood block on all the jacks and I use a wood block of 12 in just in the front jacks when is in store.In that way the front jacks stay away from the rain and dirt.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
