Champ198's avatar
Champ198
Lippert Level-Up
I'm fortunate and blessed to be able to have a 5th wheel. The 5th wheel we recently purchased has the Lippert hydraulic Level-Up jack system. Frankly, I wouldn't have added it as an option if it didn't come standard. I've always been used to manually leveling the rig from side to side with blocks under the tires, and then manually dropping the front jacks.
I didn't realize how much time that took until I used the Level-Up system. Wow, it makes unhitching and leveling so easy. Push a button to raise the trailer off the hitch, drive off, walk back, push a button and level the entire rig. When it is hot out, you'll appreciate the time savings. If you are looking at a new rig and Level-up is an option, I'd recommend it.
