rsgs
Nov 01, 2013Explorer
During the fall. I winterize WEEKLY. I run a fly fishing business early fall and hunt later fall so this requires me to winterize every week when I leave. I've done this hundreds of times, probably more. Drain all holding tanks. Empty the hot water heater (I do not by-pass until winter lay-over). Blow out the lines, opening each faucet individually to drain. Open the low-point drains. Drain fresh water tank (if used). Use bypass on fresh water tank to draw up 2 cups of red pop. Pour 2 cups in traps - Done. Never a problem in 9 years.
About Fifth Wheel Group
