TakingThe5th
Nov 06, 2013Explorer
Bob1180 wrote:
Is there any order that you blow out the lines? Like the farthest fixture first, or the closest first? Then the down lines.
* * edited * *
I start by draining the hot water tank, turning on the HW bypass, and uncorking the low-point drains, then close the low-points and blow everything out in any order - then blow everything out a second time - should not blow out any additional water the second time. Drain your low-points again and you should have all the water out.
About Fifth Wheel Group
