jerem0621's avatar
jerem0621
Explorer II
Oct 08, 2016
Blue Ox Gooseneck and Fifth Wheel Adaptor
I found out today through some searching that Blue Ox has redesigned their gooseneck hitch. It use to be called the "Diamond Hitch" but now its called the twist and flip gooseneck hitch.
Here is a Link to the gooseneck product page.
Something that I have liked about the Blue Ox gooseneck hitches in the past is that they do not require reaching into the bed wheel well to engage a locking handle.. everything is done from within the bed. This new version of the hitch has a locking collar that allows you to lock the hitch ball into place.
But, there are a lot of gooseneck hitches out there and this new version is not what got me thinking about posting.
What I found interesting what when I looked at the part numbers and descriptions. I found "DH9011 - GN to 5th Wheel Rail Adapter"
Here is a link to the installation instructions for this adaptorDH9011 Fifth Wheel Adaptor
At first glance this looks very similar to a Curt X5 adaptor. Basically, this adaptor adds fifth wheel rails to your truck bed that is secured via the gooseneck hitch.... Pretty good idea. But one of the complaints that I have read about the Curt X5 is that there is no way to draw down the adaptor to the gooseneck hitch.
The Blue Ox adds a draw down bolt to the adaptor to create a really tight installation and draw the adaptor down tightly to the bed.
Of course an advantage this adaptor gives is the ability to have a totally clean bed when not towing and a set of fifth wheel rails that you can use any standard fifth wheel hitch with.
I just wanted to share as this is another good looking, affordable option, to be able to haul a fifth wheel and have a flat bed.
Thanks!
Jeremiah
  • Carry a few loads of fine sand and . . .
    WHOA!! You mean you actually carry stuff in the bed? What do you think this is, a truck or something?? :E :E
  • Is it that much of a pain in the backside to just use a Reese hitch ball that just pops in the hole in the bed ? Yeah I know you have to store the ball after you pull it out of the hole, but you don't have to crawl under the truck and pound a B&W loose or worry about a locking ring getting jammed up from grit getting underneath the ring. Sorry I just see these things as a solution looking for a problem.
  • csamayfield55 wrote:
    I just don't understand all this crying about the truck bed??? IT IS A TRUCK BED FOR CRIPES SAKE!!!!
    Are all these grocery getters so prissy a couple scrathes or dents in the bed going to ruin the whole truck????
    I love the way BO did the ball hold on that gooseneack!! My B&W can be a pain if it is wet or muddy. It pretty much lives up but I have a flatbed so it doesn't matter.
    I really like the idea of the pop off rails! Seems like a very slick solution
    Chris
    Carry a few loads of fine sand and see how well that lock rings turns. Wonder if they provide a cheater wrench to engage the lock ring for when it jams up with dirt? Not criticizing, just stating a fact that it =will= happen at some point; what do you do then? I've had my B&W TO Ball stick a couple times from carrying dirt and trash in my truck's bed and, yes, I had to crawl under with a hammer and punch to free it up. NOTHING is perfect; you just have to live with it and be prepared for when something happens and, yes, I carry a hammer and punch on the road with me...just in case.
    Lyle
  • I just don't understand all this crying about the truck bed??? IT IS A TRUCK BED FOR CRIPES SAKE!!!!
    Chris
  • Oh wow, another hitch that carries the weight on the bed floor. Do we really need another? We already have the Andersen and B&W Companion.
