dsrace
Jan 02, 2023Explorer
I wouldn't trust the manufacturer numbers for a start. Go to the CAT scale fully loaded as if you are going on a trip.
2klb with a center of gravity 6-10ft behind the axles could easily remove 500-800lb off the hitch. If we assume the 1200lb is correct, that leaves the hitch weight at somewhere around 400-700lb on a trailer that is likely pushing 10k lb fully loaded. That would be 4-7% hitch weight...no wonder it gets squirly.
i agree and i do need to go weigh it once the weather gets better. we have more snow and ice forecasted for today. my guestimate was 10k to 10,500 lbs loaded.
i'm betting the tongue weight was closer to 600 lbs as that would explain why moving the two spare tires off the tail to the nose and adding apprx 100 lbs of tools made such a major difference. still wasn't enough but 85% better using my drw. i do not travel with any liquids in my tanks. considered adding 25 gals to the black tank as that is the farthest forward one.
for that trip home, i moved all the additional gear i could to the front end to help even more including the soda and bottled water. i thought that would help for the trip home. we got 100 miles and i had to stop as it didn't help, actually felt like it was worse and that made no sense what so every! the front of the camper was now 1.5" higher then it was on the way down. you could see it and i measured it at the truck stop. adjusted the wdh, did not drop the tongue any. went another 200 miles with 95% of that drive in a tail wind. handled fine with a tail wind. i could not figure out how adding all the weight to the front was making the tongue sit higher then it did on the trip down.
finally got home, exhausted, 7hr drive turned into an 8 and it was starting to rain as we pulled up. scrambling to get as much unloaded as we could when my wife tells me the roof i leaking in the bedroom and soaking the bed. the only thing one can do in that instance is just laugh. i pulled it into the building and started cleaning up the leak and setting fans up. we were hooked up to city water for that 3 day trip. i have 100 gals fresh water, 50 gal gray, 50 gal black. 2- 50 gal fresh tanks, one mounted between the axles and the majority of the 2nd one sits in front of the first axle. for some unknown reason, as i walked past the tank monitor panel, i checked the tank levels. i had emptied the black and gray before we left the park but still needed to flush them. when i pushed the fresh water button it read full. i thought great, sensors are out along with the roof leak! i walked out and opened the tank drain valve ( 1.5" od pvc pipe) and like an idiot, i was standing right in front of it expecting it to be empty. i'm sure you can guess what happened next! discharges out the side. the check valve in the water pump had been filling up the fresh water tank over the last 3 days. that 100 gals of water dropped the back end 1.5".
i am just trying to get my ducks in a row before the next dune trip. i know that the bpconversion might be a expensive bandaid but it will def control sway far better. i know that w/o moving the axles back that the weight of rail is still hanging that far back. i believe that one can be tongue heavy on a bumper hitch and experience sway from that. i think the bpconversion would add leverage but really wondering if that 6' extension forward of the axles will add any tongue weight. i know it's not the same as moving the wheels back but i wonder if it amplifies tongue weight to some small extent?? if it did then permanently moving the spare tire carrier forward would be no issue.
About Fifth Wheel Group
19,041 PostsLatest Activity: Apr 16, 2026
