Grit_dog
Jan 02, 2023Trailblazer
My first blush is that you were tongue light when loaded and you confirmed it. And the pic sure looks like the axles could should move back a little. Especially when describing the payload.
Looks like they didn’t design the axle placement right if you gave them the right loading info.
Not sure the gn conversion will help if you don’t have enough tongue weight in the first place.
Upside is looks like moving axles would be real easy on that rig.
Just spitballing but you may be able to just weld new spring mounts on and extend the brake wires. Bing bang easy. Don’t even bother cutting the old ones off unless they interfere.
But if backing the rail in and pulling a little more weight up front works that seems even easier.
About Fifth Wheel Group
19,041 PostsLatest Activity: Apr 16, 2026
