valhalla360
Jan 03, 2023Navigator
dsrace wrote:
I wouldn't trust the manufacturer numbers for a start. Go to the CAT scale fully loaded as if you are going on a trip.
2klb with a center of gravity 6-10ft behind the axles could easily remove 500-800lb off the hitch. If we assume the 1200lb is correct, that leaves the hitch weight at somewhere around 400-700lb on a trailer that is likely pushing 10k lb fully loaded. That would be 4-7% hitch weight...no wonder it gets squirly.
i agree and i do need to go weigh it once the weather gets better. we have more snow and ice forecasted for today. my guestimate was 10k to 10,500 lbs loaded.
i'm betting the tongue weight was closer to 600 lbs as that would explain why moving the two spare tires off the tail to the nose and adding apprx 100 lbs of tools made such a major difference. still wasn't enough but 85% better using my drw. i do not travel with any liquids in my tanks. considered adding 25 gals to the black tank as that is the farthest forward one.
i believe that one can be tongue heavy on a bumper hitch and experience sway from that. i think the bpconversion would add leverage but really wondering if that 6' extension forward of the axles will add any tongue weight. i know it's not the same as moving the wheels back but i wonder if it amplifies tongue weight to some small extent?? if it did then permanently moving the spare tire carrier forward would be no issue.
So based on your description, you are grossly under weight on the hitch.
More weight on the hitch is almost always good so long as you don't overload the truck weight limits.
I'm not sure what this contraption will do. How much does it weigh and where is it's center of gravity? Moving the hitch further forward will reduce hitch weight but the weight of the contraption might counter that. You are still likely going to be light on the hitch.
Definitely get it weighed before putting a Band-Aid on that may or may not do anything.
About Fifth Wheel Group
19,041 PostsLatest Activity: Apr 16, 2026
