Grit_dog
Jan 03, 2023Trailblazer
The lack of quotes is confusing, but anyway….
You’ll gain most of the contraption weight on the pin weight and a bit less of the actual trailer weight, so won’t gain a whole lot of pin weight.
Whoever said too much tongue weight can cause sway as well is partially kinda right. But generally it’s only when the tow vehicle is quite under sized and under sprung.
Sure would be nice to be able to demo one. That’s a lot of coin for something that may help you.
I’d move the axles back for way less money ifn I “had” to correct the problem and could t do it by shuffling gear around.
About Fifth Wheel Group
19,041 PostsLatest Activity: Apr 16, 2026
