dsrace
Jan 07, 2023Explorer II
Grit dog wrote:
Reading your other thread about the purchase, I’ll suggest based on what you wrote that you may have had them build a unit that they just couldn’t get the weights as you needed them to be.
yes i did give them the info with the hopes they had some sort of modeling program they could feed the info into. apparently they do not or forgot to or they do not want to move axles on the frames. either way this is what it is. i do understand that is difficult with out know what everything will weigh, forward of the axles, on a custom build. they buy the trailers from lci and modify them, some.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
