Dayle1
Dec 07, 2016Explorer II
otrfun wrote:Dayle1 wrote:I'm hoping to cut and flare exact lengths for my install, too. Given some thought about using copper/nickel brake lines. Supposedly this stuff is much easier to work with than regular steel lines. It costs more, but for ease of use I might use it if there aren't any serious drawbacks in terms of strength and durability.
I agree, that is why I routed my lines differently. Rather than on the face of the frame and right next to the tires, I ran them along the inner edge of the frame. Part of the way it is tucked next to the propane line including the crossover. I also used exact length lines rather than universal lines with exposed excess coiled lines.
I used stock lengths, eTrailer sells a 66" piece intended to match the frame rail spacing for the crossover line. 30" lengths are a close enough match for the axle spacing and in my case were ideal from the crossover to the front axle. Finally a 10 ft length worked from the pump to the crossover
About Fifth Wheel Group
