mapguy
Dec 07, 2013Explorer
Dexter used round magnets on pre 1988 mobile home axles. These won't work right in place of a newer oval magnet.
How are your shoes? How about the wear surface in the drum that the magnet rides. Are the magnets worn out or wires bad....if worn out the shoes and springs should go, too. Drum replacement is usually a better value than having drums resurfaced on two surfaces by someone that knows how.
IMO if magnets are worn out. It is time for new brake assemblies as the shoes a probably nearing end of life, too. Springs are probably heat fatigued, too. If cost is your concern ...6K magnet is about $25-$30. At etrailer.com you can buy complete 7k rated manual adjust 12x2 for $45 each -free shipping over $50
Yes it will be costly on a triple axle rig to go thru the brakes completely but it is the right thing to do in regards to safety. Your signature trailer is old enough to need a careful look at the brake system.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
