Cummins12V98
Oct 18, 2016Explorer III
Hunter11 wrote:
A quick search on the NAPA UP-7136-M cross reference to Raybestos shows PGD215M. I have been wanting to get new pads for our trailer and swap them out the first chance I get for better pads. Guess I need to make sure the Raybestos PGD215M will fit before picking some up.
They will fit if cross referencing the NAPA pad you list. I took the number right off the box. Let me know if they are US Made. If so I will be going that route next pad change.
Ceramic are NOT always the best option. Quality Semi Metallic are for the RV disk brake application.
Don't forget to check your brake fluid often! Also be sure to use synthetic lube for all contact points and slide bolts on the calipers.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
