Cummins12V98
Nov 03, 2016Explorer III
ford truck guy wrote:Cummins12V98 wrote:Hunter11 wrote:
A quick search on the NAPA UP-7136-M cross reference to Raybestos shows PGD215M. I have been wanting to get new pads for our trailer and swap them out the first chance I get for better pads. Guess I need to make sure the Raybestos PGD215M will fit before picking some up.
They will fit if cross referencing the NAPA pad you list. I took the number right off the box. Let me know if they are US Made. If so I will be going that route next pad change.
Ceramic are NOT always the best option. Quality Semi Metallic are for the RV disk brake application.
Don't forget to check your brake fluid often! Also be sure to use synthetic lube for all contact points and slide bolts on the calipers.
I just looked into getting replacement pads for my 8k Titan system.. the NAPA box part # UP-7136M shows made in Mexico... Not sure what to use now?
I would check into RayBestos or possibly AC Delco. Some of these companies have a PRO series.
I think if you went to RockAuto.com and put in the NAPA # it will show all other pads that match and I think they may show country of origin.
I was in the middle of the project when I picked up my pads or I would have looked further. If you find something let us know.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
