Does anyone here think it is necessary to have heavy duty brake pads on your truck while towing, and are there heavy duty brake pads available for an F-150 or F-250? I ask because at a recent routi...
Ford OEM pads are the best compromise between friction and wear, in my opinion. Not on all years, but in my opinion for your truck, you cannot beat the OEM pads.
Make sure you tell the counterman at the dealership that you want brown box Ford OEM pads. NOT Motorcraft replacements. They would like you to believe that Motorcraft is always the same as the original pads that came on your truck, but they are not.
I would replace the rotors, even if I had to buy them.
