jjbrown6818
Apr 14, 2014Explorer
Brake Wiring?
I have encountered a problem with my 2009 Montana 5th wheel (GVWR 15500). Some background first. I have had some blowouts on both sides. I also replaced my umbilical cable (7 pin). I replaced the cable because the molded plug end at the truck had come loose and exposed the wired. I have a 2014 RAM 3500 with a 7 pin plug in the bed. The truck has an integrated trailer brake. I have an error that states that I need to check my trailer brake wiring. It is sometimes followed by a notice that the trailer is disconnected. The warnings disappear within seconds and checking the brake verifies that the brake is working as expected. I know this is a problem and new because just before getting this truck, I had the same problem with the truck I traded in (2012 Ram 3500). I thought that was a problem with the truck, but now that I have received the same warning with this new truck I suspect the trailer.
Now, what have I done so far? I checked the umbilical cable and the connections appear to be clean, neat, and tight. I haven't taken them apart but there is no apparent corrosion or misconnection. I visually checked the wires at the back of the wheels where the brake wires go into the wheel area. No chaffing or breaks or corrosion.
What is the next suggestion? I am on the road and don't have a clue of where the brake system wiring runs. All the trailer lights work correctly and don't go out except as
commanded. I have looked through all my paperwork but don't know where the wires run or how they work electrically. I have the integrated brake set to 4.0 for effective braking.
