SidecarFlip
Feb 27, 2018Explorer III
DiskDoctr wrote:
I have 4R100, which is a close cousin to your e40d.
On our 2002 7.3L Excursion, we switch over from stock trans cooler to 6.0L trans cooler for about 3x the size that bolts into the stock location. Not sure if yours will allow the same?
Another thing is the temp. These transmissions can do 250F for an hour without trouble. (IIRC the info from a former Ford Transmission expert)
I would wonder pretty quickly about WHY your temp gauge stopped working? Is it possible you lost fluid or circulation or something?
When did you last change the transmission fluid?
If you'd have bothered to read the ENTIRE thread, you'd have seen he said he'd changed it every 50K miles, which in reality isn't nearly enough...
About Fifth Wheel Group
