Hello Everyone , I have a 1999 Prowler 5th wheel. It has a Dometic Fridge . The fridge works on the gas side but not on the electric side . thought maybe it was element by what I have read on ...
I would be looking at a failed circuit board. Here is test. Turn off the 120 volt supply to the rig. Locate the two wires that go to the element on the circuit board. Connect a known good 120 volt supply to the element directly. See if the refer cools. You should notice cooling in the refer and heat in the stack in a very short period of time. Maybe thirty minutes. THIS IS ONLY A TEST! Do not leave unit un attended! A poor contact in the circuit board relay could be causing the problem.
