dinwiddi
Jan 29, 2016Explorer
tcamper, I think the answer to your question is no. The B&W Turnover ball and gooseneck hitch is different from the gooseneck ball and hitch that came with your puck (4 points) gooseneck hitch (center point) system. The hole that the ball fits into is square on the B&W and round in the Ram. The people at etrailer.com can help you with this. I had intended to install a B&W Turnover with a B&W Companion Slider 5th wheel hitch but traded for DRW with the trailer prep package, so no slider was needed.
I think you will need a "picture frame", that fits in your pucks then put the B&W slider onto that frame as B&W did not make a slider that fit the pucks at the time I was researching this.(Need to check this out as some said they were planning to produce one.) This adds about 2" height that may or not be taken care of in the hitch adjustments. Good luck on your experience.
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
