laknox
Jul 22, 2021Nomad
ford truck guy wrote:laknox wrote:ford truck guy wrote:
Jerry, really?? You want Ron to report you to the B&W club??
Did you know there is 1 single grease zerk as well?
There =should= be 3. Should be a 90 zerk to grease the head pivots so you can grease without having to take the head off to do so. Been wanting to drill and tap these for years, but have never gotten roundtuit. :-)
Lyle
I only have 1... The bushings are accessible once the head is removed...
HITCH MAINTENANCE
Grease the saddle through the grease zerk
approximately every six months with multipurpose grease. This allows the coupler to
pivot freely.
As needed, grease the polyurethane bushings
with high-grade lithium grease.
Spread a thin layer of multi-purpose grease around the
inside surface of the jaws where they grasp the kingpin.
On page #24 is the maintenance - B & W maintenance - Companion Ford Puck
Yes, I do do this, yearly. (I don't tow all that much, right now.) Jaws get greased every couple trips.
Lyle
About Fifth Wheel Group
